spwiddy avatar image
spwiddy asked
Calcium Battery Charge voltages.
No matter where I look I cannot find any information regarding the charge voltages for my 12 Calcium batteries
One internet search suggested that the AGM charging specs were the correct ones for Calcium batteries
Can anyone help out with the voltages required?
Bulk, Absorb, Float.
Rgds,
Steve.
CCGX Color Control
@SPWiddy
Are you running a 12v system? Generally they are around the same voltages as lead acid based, usually a little higher though. What brand do you have and is there no information on a sticker down the side of the battery?
Are you sure they are designed for inverter systems (cycling)?
