Hi, I’m installing a solar controller 75/15...
a little tight for space...can i install it at 90 degrees so the fuse is on the left side or does it have to be sited the right way up with writing horizontal?
thanks
thanks
Hi @Rusty Noggin,
the manual clearly says to mount vertically with the power terminals facing downwards. And in a well ventilated area.
If you want to keep your warranty, then you have to follow the installation instructions.
I did read instructions... as I didn’t see any vents I thought I would be ok..
my panel is a 100w
thanks again
47 People are following this question.
