Hello.
I will connect a Smart solar charger 150/70 with 3 battery bank's located separately. How can I monitor the temperature of each bank? Installing 3 smart sensors each one with every bank will work?
Thanks
Hello.
Thanks
Not sure if this helps, but from the VE.Smart Networking manual:
"It is not possible to measure multiple battery temperatures/voltages/charge currents: only one Smart Battery Sense, or one BMV can be used in a system. Having multiple sensors connected to different batteries can lead to charging issues as overcharging or heating up the batteries."
So looks like the answer might be no; but I'm no expert sorry.
Here is a link to the VE.Smart Networking Manual (check out section 5 limitations).
Victron temperature sensor disambiguation table - which product supports which sensor
22 People are following this question.
