JB Hughes avatar image
JB Hughes asked
New install, no power after updating with MK3- Multiplus 12v/3000
New install in an RV with lithium batteries, all lights were on and working. Inverter was working properly. I got a MK3 dongle to be able to program the charge parameters for the lithium battery bank, and after doing so and updating all firmware and uploading settings, now I have no lights in the Multiplus and the inverter won't power up. Voltage measured at the terminals on the inverter checks out good. I suspect that my computer is being recognized as a virtual switch and it is waiting for a signal to power on, but now I can't connect to the inverter because it is off. Is there a way to do a "hard reset" or "trick" the unit into turning on?
MultiPlus Quattro Inverter ChargerMK3
What batteries do you have?
Installing the FW again should reset all settings to default.
JB Hughes answered ·
I have 3x 200Ah KS2 lithium batteries with built in BMS. They disconnect the charge side at 13.6v so I need to reduce the charge voltage from the Multiplus. How do I install the FW if I can't power up the inverter?
Try to use VEflash an go through the update process like normal.
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
