Can anyone help please.
The loads on my CCGX stays on 1W even though the output to loads is 6.8A @ 230V , the CCGX should read ±1564W. What could be the reason
Please provide more information about the setup. Are you running ESS? Do you have an energy meter?
Hi Warwick,
Than you for responding to my question, we got the issue resolved. I switched everything off and everything on again and the issue was sorted out.
Again my thanks
Johan
Hi Warwick,
Thank you very much for responding to my question, the issue was resolved. I switched everything off and also isolated the panels and the batteries and after restoring everything the consumption readings showed again on the CCGX
Regards
Johan
39 People are following this question.
