peterb381 avatar image
peterb381 asked
What PV is Best for my Victron 100/50 with 120AH AGM?
Hey guys, really after some help, as I’m doing circles mostly in my mind.
I have a Victron 100/50 MPPT with a 12V Fullriver 120AH battery
…without any input, I’ve calculated it would take 1.2days to completely flatten from my usage.
My goal is obviously to recharge the battery in the most efficient way possible, with size of panels being ‘somewhat of an issue’ – as in, I would prefer smaller panels – but if it makes sense to do so, I will get creative with room to accommodate bigger panels.
Option 1: 3 x Renogy 100 Watt 12 Volt Mono Solar Panel(Compact Design)
Solar Cell Type: Monocrystalline Cable outputs: 12AWG
IP65 Rated waterproof junction box IP67 Rated waterproof MC4 connectors
Maximum Power: 100W Maximum System Voltage: 600V DC (UL)
Optimum Operating Voltage (Vmp): 17.9V Open-Circuit Voltage (Voc): 21.6V
Optimum Operating Current (Imp): 5.72A Short-Circuit Current (Isc): 6.24A
Weight: 6.5 kg Dimensions: 1074 x 498 x 35mm
Number of Diodes: 1 Diode(s) Diode Type: 15SQ045
*I may possibly go 4 panels, and these would fold up nicely as opposed two opt.2
Option 2: 2 x Renogy 160 Watt 12 Volt Monocrystalline Solar Panel
Max Power at STC: 160W
Open Circuit Voltage: 22.9V Short Circuit Current: 8.37A
Opitmum Operating Voltage: 20.2V Optimum Operating Current: 7.92A
Operating Temperature: -40℃ to 90℃ Product Dimensions: 130.3 x 65.8 x 3.5 cm
Product Weight: 12 kg
…in the forum, I’ve seen people comment for option 1 that 21.6v is a bit on the low side considering +5v for MPPT to work?
So, my thoughts for Option 1 [if I went 4 panels] would be two serials in parallel? But with all of the PV world being out of my league, I’d really like some guidance – for instance, do MPPTs prefer more voltage and less amps, or more amps less voltage (or don't they care), and it comes down to sun harvesting approach i.e. I’ve heard before higher voltage panels are better for collecting earlier and running later? Anyhow, would really appreciate anyone shedding some light ;) on the best approach. Many thanks in advance, Peter
MPPT Controllerssolar sizing
seb71 avatar image
seb71 answered ·
Don't completely discharge any lead-acid battery. You can safely use 30% of the capacity and up to 50% occasionally.
Regarding the panels: if all are installed on the same surface (same angle and same azimuth) and if there are no shading issues, the best option is to wire panels in series (taking care to stay under the solar charger maximum voltage limit, even at low temperatures).
peterb381 avatar image peterb381 commented ·
Indeed! Thanks a lot for that, I really appreciate it - in that case, the form of the 100W panels will suit me just fine. If you don't mind sparing another moment of your time, I started another Question (as it seemed quite distinct) that I would love your critique/consideration; basically, my final system layout - and whether you'd give it a 'Yay, or Nay' - at: https://community.victronenergy.com/questions/81140/victron-10050-inverter-wiring-setup-help.html
Thanks again @Seb71 - very helpful!
MPPT Product Page
MPPT Error codes
