Wrapping up an install on a boat with CCGX, 3x MPPT, 2x Multiplus, Wakespeed regulator and finding that CPU utilization is always over 4 and frequently hitting 5 on VRM diagnostics.
Was hoping to use Grafana for some custom displays, but it looks like the CPU is so maxed that real time data via MQTT is not possible.
Tried shutting off NMEA2k, and all other non mission critical services with limited improvement.
Not experiencing any reboots and the system generally runs well, but it's clearly maxed.
There is no space for a Cerbo and the cutout for the CCGX display is very different from the CERBO display.
Are there plans to release a CCGX with improved capabilities any time in the future?
Thanks
Nigel Macleod
