Hello
I installed 2 smart shunt and connected them.to a color control gx by ve-direct. I can see 2 smart shunt including the data from them in the system set up tab.
I experts i can now also see 2 Batterys in the overview (the graphic menu) menu of the colcor control. Pity enough i can only see one battery. Is this suposed to be like this? Can i also see the other battery?
Thanks in advance.
Kind regards, Piet
