uai avatar image
uai asked
Auto Gen start/stop
Howdy victron going to use a color control panel to call auto generator on multiplus inverter 3. kva cannot find in menu the trigger to call on generator as wanting to have it called by inverter low battery not grid supply as using in camper van and when no grid supply inverter batteries run system and when low to call an external generator to start thanks Ashley
Relay
JohnC avatar image
JohnC answered ·
Howdy Ashley. Might this help? https://www.victronenergy.com/live/ccgx:generator_start_stop
Your post is quite brief, so we can't tell how far you've come. Ask for more if you've specific needs.
Edit/: You may find a manual start genny in a camper more 'practical' to live with.
Paul B avatar image
Paul B answered ·
In the CCGX
You first have to turn the Gen autostart feature on
Under settings first select the relay option and then select Generator autostart so that the relay now does that option
after that the generator autostart options will apear
