leon-rudge avatar image
leon-rudge asked
Cyrix LI not charging leisure battery.
Hello, everyone. I have the setup below in my van.
I don't have the yellow signal connected from 85 to +
My lithium leisure battery isn't charging off the alternator. Is the yellow signal cable the reason why?
Everything else works fine.
I can't find an answer as to what the yellow cable does.
Thanks
Leon
Cyrix Battery Combiner
All cyrix-li are only working with a (+) signal at 85. Take a look at the manual. A "everything is ok" signal from the BMS should be connected to there.
