cmarksmith avatar image
cmarksmith asked
Cyrix-ct to control boat bank charging?
I am trying to find out if I could extend the system charging my boat's 12v 110a house and engine batteries that are linked by a Cyrix-ct. I am looking to add another (less important) similar battery that powers a winch and was wondering if it would work to link this with another Cyrix-ct? I am guessing that the problem with 2 Cyrix in the parallel system there would be confusion about which one should connect. I would like to achieve sequential charging of the 3 batteries. The charger is a Victron Blue 15a with single output that works from shore power and the alternator charges the batteries when underway.
Many thanks for your advice.
Kind regards, Colin
Cyrix Battery Combiner
Hi, @cmarksmith, sorry nobody has been able to answer. Its not so easy to answer perhaps.
What I can say is that indeed each Cyrix will connect by its own logic, there is no smart prioritizing. And to be frank I wonder if there should be.
Keep it simple is my advice.
Having two cyrixes in parallel, one to the winch battery and one to the service battery should not be a problem.
