millennial-mountaineer avatar image
millennial-mountaineer asked
What settings for MultiPlus Compact with RELION Low Temperature Lithium batteries
Hi everyone! Thanks for looking at my question!
I have a 600Ah Battery bank (2x RB300LT batteries from Relion) The batteries are specifically designed for low temperatures with built in heating elements, controlled by the BMS.
My question:
Are there any specific inverter settings that would optimize safely charging these batteries during low temperatures? And, if so, when the temperatures warm up, would I need to modify these settings?
Ideally, I would like to be able to set a range, and not for the seasons if possible.
Thanks!
Equipment list:
Van conversion-
Inverter: Victron Multiplus Compact 12v/2000w/80amp
Batteries: 2x RB300LT batteries Relion
B2B: Sterling 60Amp (1260 model)
Alternators: 2x Factory Installed 230Amp alternators
MultiPlus Quattro Inverter Chargertemperaturerelion
