falco avatar image
falco asked
MultiPlus & Cerbo GX & Mk3 to USB
I have a MultiPlus, Cerbo GX, BM712, Mk3 to USB, and a VE Bus smart dongle. I used the smart dongle and usb to mk 3 before I purchased the Cerbo GX
I have everything plugged in and running ok, but was wondering if its ok to plug the Mk3 to USB in to the 2nd VE Bus port on the Cerbo GX. And I presume I cant plug the VE Bus smart dongle into the Cerbo GX as it only has two VE Bus ports. Is that correct.
cerbo gx
falco avatar image
falco answered ·
I am going to answer my own question here..... Yes the Mk3 to USB does work when its plugged into the VE Bus of the Cerbo GX
But if you want to update the MultiPlus firmware, connect the MK3-USB directly to the inverter and disconnect all other VE.Bus devices from it.
