avinesh avatar image
avinesh asked
EasySolar takes alot time to connect to grid and grid export is zero
Hi @Guy Stewart ( victron energy staff)
I have a grid connect system setup using 1x easysolar 3k, 240kwh BYD battery bank. The system was programmed with ESS assistant. The inverter takes alot of time to connect to the grid onces its available (6 to 10 hrs) also even the excess feedin is enable in ESS the system does not export to grid.
I can give access to you for the vrm portal.
Any help will be appreciated.
EasySolar All-in-One
