ak-pilot avatar image
ak-pilot asked
Alternator energizing problem
I installed a 80-2SC on my 2013 Cadillac EXT. The alternator does not work as it needs some current to excite it. I have looked at the units that have an "Energize" connection but the wiring diagram shows it connected to the alternator at a connection other than B+. My alternator only has the B+ terminal. Can I connect the it to the B+? Ideas on how to make this work?
Orion DC-DC Converters not smart
billknny avatar image
billknny answered ·
A "B+" connection is used only for connecting the Battery positive wire that feeds the alternator power to the battery. Normally on a road vehicle, the negative connection is made from the alternator case to the the engine block and then to the frame ground. Your alternator is almost surely internally regulated, which means it does not need--nor can it use--an external source current to excite it without significant modification.
ak-pilot answered ·
An alternator unlike a generator has to have some voltage to energize the field winding and create the magnetic field to generate electricity. I know older cars get that through the idiot light. My application does not have a connection for that exciter voltage. It apparently gets power from the B+ connection which is always hot. I'm trying to figure out how to provide that when connection two batteries with an isolator. The B+ on the alternator would feed the isolator input and would not be directly connected to the battery so there is no exciter voltage to start the alternator working.
billknny avatar image billknny commented ·
I am not sure that I understand what your issue actually is. Generators DO actually require excitation of the field coil, it just happens internally. Like on your alternator.
Do you understand that if you disconnect the B+ terminal from the batteries while the alternator is charging the diodes in the alternator will be destroyed by the resulting voltage spike? If that is clear, to you, then maybe someone else can help.
ak-pilot avatar image ak-pilot billknny commented ·
batt-isolator.jpgA generator has permanent magnets so will charge with out any exciter current. I do appreciate your attempt to help. In my vehicle the alternator B+ is always connected to the battery. I'm trying to add an accessory battery to the system that will be charged separately from the vehicle battery. Keeping the stock set up I can't isolate the new battery without it potentially drawing down the vehicle battery.
gro avatar image
gro answered ·
The diagram you have provided shows connections that should work.
Alternators have gone through an evolution of how they are regulated, initially external regulators were used then they were placed together with the alternator. More recently some vehicles are using a PWM signal generated by the vehicles ECU. If your alternator just has the connection to the battery then it has an internal regulator.
4 comments
ak-pilot avatar image ak-pilot commented ·
Thanks, I know it has an internal regulator. With it connected by my diagram if there is a load on the accessory battery while the truck is not running it will also drain the vehicle battery. I'm trying to isolate the two so if one gets drained the other will still have power. I may have to go with a relay instead of an isolator so the batteries will not be connected unless the vehicle is running. I have used an isolator on older vehicles that had an alternator with an internal regulator but a connection for the exciter current separate from the B+.
gro avatar image gro ak-pilot commented ·
You can go two ways which are fairly simple.
NARVA 61092BL VOLTAGE SENSITIVE RELAY 12V VSR 140A DUAL BATTERY
the other way is to take a circuit that is live when the ignition is on. I have previously used an ignition activated circuit to trigger a relay. Unfortunately the relay has to be big enough to handle at least the alternators capacity as the vehicle battery and alternator will dump a fair bit of current into a flat house (auxiliary) battery. As soon as you get a simple relay with that current capability it will draw a bit of power such that the relay gets pretty hot. I’d go with a Voltage Sensitive Relay (VSR). The VSR will hold both batteries together until they get down to 12.7V. Below that the batteries will be isolated from each other allowing you to draw down on the house battery without jeopardising that your vehicle/starter battery will go flat.
ak-pilot avatar image ak-pilot gro commented ·
Thanks, that was plan B. I do have an 80 amp relay but I was hoping to use the isolator and not have to tap into an accessory wire.
So does your isolator work? How does it work? Is it a set of diodes or some voltage sensing relay? No matter how it works if it is functional it should do the job. Just have to get out there and wire it all up.
