Stojan Nejkov avatar image
Stojan Nejkov asked
MPPT BlueSolar 150/60 skips absorption cycle after update to firmware v1.39
I have just updated my MPPT BlueSolar 150/60 to the latest firmware v1.39.
The next day what I noticed is that there was no absorption cycle. Instead the MPPT went straight into Float mode.
Also I noticed that after the upgrade the MAX battery voltage was only 53.96v - it has always been around 58v (which is the manual configuration I have in the MPPT settings)
Is this normal behaviour?
Has anyone else go the same issue perhaps?
I have a 48v battery bank (4x 12v AGM 300A batteris in series) with 36 solar panels PV and a Victron MultiPlus inverter.
thanks
stojan
MPPT Controllersfirmware update
Stojan Nejkov answered ·
Hi All, after playing around for a couple of hours it is working back to as it is supposed to be.
Here is what I did:
1) disconnected PV, then disconnected the Battery bank - waited a couple of minutes
2) connected battery bank then PV
3) went into setting and loaded my previous backup - still the same issue - ( I should have probably done a factory reset first then load the settings...)
4) did a factory reset and then manually adjusted the voltage settings for absorption and float
5) saved settings in a new backup file
now working as normal - absorption at 58v.
hope this helps.
cheers,
stojan
Thank you for the follow up reply.
Sometimes it just takes a bit of time to take care of these issues. Othertimes, a walk :)
It can be tricky with a new firmware launch to know what is a new problem, and what isn't. So I was watching this one.
Thanks again for the initial report and the report back.
MPPT Product Page
MPPT Error codes
