vango-sho avatar image
vango-sho asked
Coonection between Smart BP-65 and BMV712
I am a little confused and have read my tips which sometimes have been conflicting and confused me more.
If feasible I would like to have a Battery protect to prevent a charge from dc-dc orion, MPPT and the IP22 charger. The intention is to set up the relay parameter in the BMV712 and when the temperature or voltages are outside certain parameters ( below 5 degrees) the Battery protect, using the remote feature, would turn off.
I would like to know if this is feasible?latest-v1.jpg and if this is ok which connections do I need to make?
The objective is to protect my lithium battery against charging at cold temperatures.
I have included a diagram of my setup which does not have the BMV to Battery protect relay connection.
Also attached is my current setup, which shows the 2nd BP-65 not connected and this will remain like this until I can found the correct safe solution.
Any help much appreciated
BP2.pdf
BMV Battery MonitorBattery Protect
bp2.pdf (790.8 KiB)
Victron BatteryProtect product page
