stampy avatar image
stampy asked
Using a SmartSolar MPPT 75/15 Charge Controller and Dakota LiFePO4 batteries, what would be the best Load Control setting to power four Dual USB charging outlets?
We are using both a Victron charge controller and Dakota Lithium batteries in one of our solar charging stations. The system will be used for charging smartphones and tablets, with power requirements for these devices ranging from 12W to 25W. Our specific concern relates to charging stations we are getting ready for a high school district where usage could be heavy. The component configuration is:
  • SOLAR ARRAY: 100W (4x 25W mono solar panels, two series in parallel)
  • CHARGE CONTROLLER: Victron MPPT 75/15
  • BATTERY BANK: Two (2) Dakota 12V 10Ah LiFePO4 batteries, wired in series for a 24V system
  • LOAD: Four (4) dual USB/USB-C Charging Outlets
We want to maximize the 240Wh battery bank and are wondering which Load Output configuration would be best. I read in the Victron manual that Setting 2, “Battery Algorithm,” maximizes the life of the batteries but we’re wondering if it will limit the charging capabilities on a busy day leaving substantial capacity unused. And, we wonder whether other settings such as “Always On” or one of the “User Defined Algorithms” would be better suited to our application.
MultiPlus Quattro Inverter Chargersmart solar charging behaviour
marc-de-montreal avatar image
marc-de-montreal answered ·
hi,
lifepo4 have a 3000-5000 cycles life (and more if using 80% SOC).. i don’t think you need here any algorithm for a better lifetime (more than 10yrs is more than enough)..
Marc
