mvader (Victron Energy) asked
Venus OS v2.63~1 available for testing
Goood morning!
In an attempt to keep the pace up, here already is v2.63~1. Changes below. The goal is to have this one to be a short cycle one.
This post is intended for all people participating in the Venus OS Beta test program.
And, in case you hadn't seen it, v2.62 has been released officially now. blog post here and as always much obliged for all your input!
Changes in v2.63~1
VE.Can communication
  • Fix bug that caused a crash when the custom name was a single character.
  • Fix recently produced Inverters RS-es not being recognised (HQ2049 and newer)
  • Add VE.Direct Inverters to the NMEA2000-out feature.
  • Make setting the mode (on/off) for the Inverter RS
VE.Direct communication
  • Improve how the VRM device instance number is obtained. This fixes VRM instance renumbering occurring sometimes for products such as Solar chargers or BMVs when connected via USB.
  • Add kWh data for the Inverter RS (but this needs more work to actually be seen on VRM; pening)
VRM Portal
  • Include all solar data for both MPPT RS and Inverter RS
  • Include kWh data for the Inverter RS (but this needs more work to actually be seen on VRM; pending)
  • Update Ignore AC-in transmission to new standard
Remote firmware updates
  • Various improvements, and increase baudrate for MPPT RS updates from 19200 to 115200.
Thats all for now, for any regressions (= things that used to work but no longer work since this new version) and also any other possible bugs, welcome to post as an Answer below.
Have a good day. Matthijs
Venus OS
