ewalderasmus avatar image
ewalderasmus asked
Pylontech US3000C Charging Characteristics
Good day all,
It is my first time installing a 3000C pylontech battery, and the charge curve looks very different to the US2000B I have installed before. The settings are all correct and the device is happy, the only thing I can think of is that the battery BMS is not asking for current, which is different to my us2000B installation...
Any one else seen this? I assume it is normal as the system works flawlessly, just very odd.
Side note- I did use a type A cable and not a type B cable as per the updated Can bus communication report
battery chargingPylontech
checkit avatar image
checkit answered ·
@EwaldErasmus I am seeing the same behaviour with my two US3000C batteries. As soon as the batteries start discharging the charge current limit changes to 74A. When the batteries reach 100% SOC the charge current limit drops to zero - indicating that they will not accept any more current. Seems totally normal to me. The US3000C batteries are probably not running on the same firmware as the US2000's.
ewalderasmus avatar image ewalderasmus commented ·
@CheckIT
Thank you very much! As long as Im not alone then im happy.
Please change your comment to an answer so I can mark it as correct.
Hi @EwaldErasmus
A new battery needs to be kept fully charged until this doesn't happen anymore, this way the battery can balance properly. after it is fully balanced, this behavior should not re-occur.
Hi @daniel
Thank you, the battery has been on charge/connected to the system for over a week and a half and still doing that.
The SOC says 100% and has been at that continuously.
We experienced some loadshedding last week and the batteries were drained to 75% and charged up again and the same charge cycle continues.
I haven't seen many people post about the 3000C models, Could it be a charging characteristic which is unique to these 3000C's?
Regards Ewald
Matthias Lange - DE avatar image Matthias Lange - DE ♦ ewalderasmus commented ·
You should ask that question Pylontech not Victron.
Victron Pylontech battery compatibility guide
