My History record the same value every day so get the same values from day 1 till the end although is charging and as well during the day 0 value are changing.
anyone experience such issue and what the best to correct it
cheers
Jorg
cheers
Jorg
Can you make some screenshots of you settings, the history and live data s?
Hi jorg,
A firmware update of the MPPT Control is required to fix this issue.
The firmware can be updated by either of the following methods:
Kind regards,
Thiemo van Engelen
Hi @jorg,
Can you please provide the firmware versions of both the SmartSolar and the MPPT Control? I suspect that they are not running the latest version, which might explain this issue. To verify this, please disconnect the MPPT Control and reconnect it. I can be that the history is then updated to the values of that moment.
Kind regards,
Thiemo van Engelen
Dear Thiemo,
Thanks for your prompt reply, my version is 1.16
regards,
Jorg
Hi jorg,
What is the software version of the MPPT Control?
Kind regards,
Thiemo van Engelen
47 People are following this question.
