felixsteinbeis avatar image
felixsteinbeis asked
E1 error Smart BatteryProtect 220
Hello all,
I have a Smart BatteryProtect 220. When I activate the Smart BatteryProtect without any load on the output, I get the error E1 (short circuit).
Only with a load on the output I can activate the Smart BatteryProtect.
Is this a normal behavior? It is definitely not a short circuit, only an open output.
Thank you very much.
Best regards
Felix
Battery Protect
4 comments
felixsteinbeis avatar image felixsteinbeis commented ·
Who can help me, please?
Alexandra avatar image Alexandra ♦ felixsteinbeis commented ·
@felix.steinbeis
Maybe some more information about your system would help.
The distance from the battery what size cable battery etc.
I had read a while ago somewhere on the community that the distance from the battery and undersized cabling can cause this issue.
felixsteinbeis avatar image felixsteinbeis Alexandra ♦ commented ·
Hi Alexandra,
Attachted there is an image from my system.
The SBP220 is connected to the lithium battery about a 150A MRBF fuse within a distance of 20 cm with a 35 qmm cable from IN (battery +) to OUT (load).
The SBP65 is connected to the lithium battery about a 30A MRBF fuse also within a distance of 20 cm with a 35 qmm cable from IN (charger) to OUT (battery +).
When no cable is connected to the SBP220 OUT I get an error E1.
Thanks.
Felix
@felix.steinbeis
Sorry the image cannot be viewed
felixsteinbeis answered ·
Is the SB220 possible faulty?
