clintonhebb avatar image
clintonhebb asked
Multiplus 12/3000/120/16 shuts off after drawing AC inverted power for few min
i have a Mulitplus 12/3000/120/16 in my van & when i turn on a space heater at 800w it runs it for a few minutes then shuts multiplus down. I don’t know if it turns back on as i have just rebooted it each time.
any help would be appreciated.
I have a 60aH battery at the moment but intend on upgrade it soonish.
I’d like to be able to boil a kettle during my work day. But is shuts down immediately when i swithch kettle on.
thanks
Clinton
Multiplus-IIMPPT Controllers
rslifkin avatar image
rslifkin answered ·
What's the battery voltage doing when it shuts down? With that amount of load, you're pulling an awful lot of power for such a small battery. I wouldn't be surprised if it's pulling the voltage down enough to hit the low voltage cutoff.
clintonhebb avatar image clintonhebb commented ·
I’ll have to do a wee test to see.
I also might have found the answer in another q&A,
i have 35mm cable from battery protect to Lyncs bus Bar & 50mm from batteries to battery protect. I knew this could have been a problem ans was planning to change them out but wanted to get it up & running & only had 35mm.
thanks
There should be a red LED on the Multi.
I also think it is a low voltage cut-off.
What kind of battery do you have? lead or lithium?
A MultiPlus must not be connected to a BatteryProtect!
(Reverse current flow during charging)
7 comments
Ok, I’ll check into it.
Multiplus its not connected directly. Multiplus is connected to lyncs distributor
when you say “low voltage cut off” are you suggestion that i can change a setting & it will fix the problem or i need bigger battery capacity?
Matthias Lange - DE avatar image Matthias Lange - DE ♦ clintonhebb commented ·
As long as the Multi can't push energy through the BP in the wrong way (from OUT to IN) everything is fine. But to be sure can you make a wiring diagram or some pictures?
Yes there are many setting you can/should change.
You can do this with the DIP-switches inside but in my opinion this is to complicated
It is described in the manual but I never done it this way.
I would recommend to use VE.config or VictronConnect but you need a MK3 Interface for that.
clintonhebb avatar image clintonhebb Matthias Lange - DE ♦ commented ·
Ok, if everything is wired as the diagram shows your good.
Maybe I just misunderstood what you wrote earlier.
But again: What kind of battery do you have? lead or lithium?
A 60Ah lead battery can't deliver enough power for your heater.
A lithium battery most likely can do that, but will be also empty quickly (around 40-45 minutes).
60aH Lithium Victron battery
SuperPack or Smart?
https://www.victronenergy.com/batteries/12,8v-lithium-superpack
https://www.victronenergy.com/batteries/lithium-battery-12-8v
The SuperPack has a max. continuous discharge current of 30A (80A peak for 10sec).
The Smart one can deliver up to 120A continuous (<60A recommended).
You 800W heater needs at 70-80A.
So the Smart lithium should be able to power you heater.
Hi Matthias,
thanks for your help.
I have replaced the 35mm with 50mm & I have a smart lithium 60aH battery.
I just tested it the now & as the voltage drops to about 10.6v it shuts the system off.
will I be able to upgrade the battery & solve this problem?
I have loads of solar pannels so replenishing my batteries shouldn’t be an issue but I want t be able to run a kettle & press during the days.
thanks
clinton
