Can anybody tell me if the installation on the attached diagram is correct to read the midpoint charge on a battery bank. I have the same setup with 12 x 12v bateries.
Thanks
Thanks
This is an diagram out of the official Datasheet of the battery balancer so why should this not work?
There is also a wiring diagram in the manual of the BMV:
https://www.victronenergy.com/upload/documents/BMV-702-quick-installation-guide.pdf
I am not sure if the bank I got, connected in series and parallel, and to check midpoint if it is the correct way to connect B1 and B2.
I am not sure if it would is correct for my battery bank, that is connected in series and parallel
22 People are following this question.
