sun avatar image
sun asked
Can't read the dbus data using "dbus -y" command
HI all
Hope you are well.
I connected wind+MPPT to the RPI which Venus OS is installed.
And I executed the dbus-bornay-windplus.py file of github, and it works well, I can read the log.
So I tried to read the value using the following command.
dbus -y com.victronenergy.windcharger.bornay_ttyUSB0 /ProductName GetValue
But the output is:
ERROR:dbus.proxies:Introspect error on :1.47:/ProductName: dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Traceback (most recent call last):
File "/usr/bin/dbus", line 379, in <module>
ret = obj.object.get_dbus_method(method.name, iface.name)(*args)
AttributeError: 'NoneType' object has no attribute 'name'
And the output of "bud -y" is like the following.
I tried several commands(for example, "dbus -y com.victronenergy.windcharger.bornay_ttyUSB0 /Mppt/Phase GetValue"), but all failed.
What is worng?
Please help me regarding this problem.
I will wait for your update.
Thank you.
Venus OS
erfaneshrati avatar image
erfaneshrati answered ·
I have the same issue.
mr-manuel avatar image
mr-manuel answered ·
A bit late, but I found it through Google. What if you try this command? It shows you all settings of this device. Probably the /ProductName is not existing. Did you check with dbus-spy?
Try
dbus -y com.victronenergy.windcharger.bornay_ttyUSB0 / GetValue
or to see, it it's working at all
dbus -y com.victronenergy.platform / GetValue
Here a link to the wiki entry: https://github.com/victronenergy/venus/wiki/commandline---development
