Trevin Corkery avatar image
Trevin Corkery asked
Charge preset for flooded lead-acid deep cycle marine battery?
I have the Victron SmartSolar MPPT 100/20 and I can't seem to find a correct preset for flooded lead-acid batteries. Which should I use?
MPPT Controllersbattery
joeoffgrid avatar image joeoffgrid commented ·
Same question here for maintenance free flooded semi-traction calcium 12V as well as starter battery.
I guess your best bet is asking the battery maker (incompetent in my case).
Paul B avatar image
Paul B answered ·
You would need to do the research yourself as to the best voltages that suited your batteries.
or just go generic and adjust as needed.
A good starting point would be
Bulk: 14.4
Absorption time: 4 hrs
float 13.6 to 13.8
Keep a good eye on the batteries and check there water levels if they start to use water then reduce the bulk and float voltages by 0.2 volts
MPPT Product Page
MPPT Error codes
