vtwin996 avatar image
vtwin996 asked
Waterproofing a Smart Shunt
I recently installed a Smart Shunt in the battery box in my Class A motorhome. The shunt worked fine until the first trip after which it was reporting crazy numbers and would not connect reliably to the app via bluetooth. The battery box is semi enclosed with several sections open for venting. I was driving in heavy rain and wondering if it got wet enough to cause the problems. I replaced the unit but need to some ideas to water proof the shunt. Doesn't look like Victron sells a waterproof box for this unit.
SmartShunt
lehrling avatar image
lehrling answered ·
How much room do you have for a box?
Can you upload a pic of the mounted shunt?
vtwin996 avatar image vtwin996 commented ·
img-1167.jpgA couple of pictures
seb71 avatar image
seb71 answered ·
Get a IP65 enclosure and use cable glands for all cables.
lehrling answered ·
If you want to go a little more hillbilly, boxes with lids like these are cheap, available anywhere, and easier to access in tight spaces for maintenance.
dfraizer avatar image
dfraizer answered ·
I have the same problem, but on a boat application. I just ordered a water tight NEMA box with a clear cover and water tight glands. The other issue is that the 1 am slow burn fuses are not in a water tight fuse holder so I bought BlueSeas waterproof fuse holders.
DFraizer. Could you tell me which box you ordered? Thanks.
