version 1.54 broke my system and no one seems to be able to help
I see that there is two version of that FW haVE YOU ISNSTALLED THE CORRECT ONE ???
now a Rev 2 version of the 1.54 Fw so maybe install that if you have not already tried, OR TRY THE NON Rev 2 version
may help may not
hi Paul B i have tried this option without any success
I presume the updates are being done locally by using bluetooth connection. if not try locally
From the way I understand, I think he can install the firmware just fine, but he has some unspecified issue with his charger when using the newer firmware version(s) and he would like to revert to 1.53 firmware, which is no longer available to download from Victron.
58 People are following this question.
