I am setting up a electric drive for my boat.
I have a 72v Motor running of 24 cell LiIePo4 200AH pack with a 24cell BMS system (pack has a nominal voltage of 76.8volts, I want to run this through the Victron BMV . Instructions say max voltage 95v but then in other parts of instructions it says for 12v or 24v systems? Can someone advise if this will be OK or not.
Motor has a 67AMP draw 4500w
Thanks
Deane
