chezgals avatar image
chezgals asked
Multiplus compact remote switching with third party bms
I have a MultiPlus Comapct and I'm just about to start installing my new Lipo4 set up using none Victron batteries and BMS. I have realised that the Compact does not have the same remote switching capabilities as the full version.
I have been told that I will be able to use my bms to switch over to charge only on low soc and I would use a solid state relay on the incoming generator feed to stop an over charge.
Is this the case and would these settings be done by an assistant on the ve configure software?
Any suggestions and advice greatly received as I'd assumed that the compact would have the same functionality in this situation.
MultiPlus Quattro Inverter Chargervirtual switch
