Marco Meile avatar image
Marco Meile asked
SmartSolar Temperature Compensation changes voltage in the wrong direction
Hi all,
i'am using a SmartSolar MPPT 100/30 with firmware 1.54 and a external ve.net temperature sensor.
When setting the temp. compensation to -30mV, on temperature below 25c, in my case 18c, the voltage is lowered from 29,4V to ~29,25V instead of 29,55V.
When setting the compensation to 30mV (plus) it works as expected.
Is this a bug?
Thanks so far
Marco
MPPT Controllerstemperature compensation
saskak avatar image saskak commented ·
I know it is an old thread, but I am seeing the exact same thing with my smart solar 100/40 ver 1.61 (latest version), but it does not seemed to have been answered here. I posted my question/experience here: https://community.victronenergy.com/questions/225175/smart-solar-mppt-temperature-compensation-flipped.html
Hopefully there will be someone answering any of these.
Marco Meile answered ·
pushing the bug up again
michelg avatar image
michelg answered ·
Hi Marco, just let 30mV without sign, the mppt should adapt to the needs.
Michel
Marco Meile avatar image Marco Meile commented ·
but how can that be the solution if is simply wrong. this leads into damaged batteries and must be fixed!
hey victron people, whats up?
dan avatar image dan commented ·
Hi, so have u a fix for this.
wanek avatar image
wanek answered ·
hello!
did anyone can give a proper answer for this issue?
tomas-arthuzzi avatar image
tomas-arthuzzi answered ·
Anyone from Victron will ever respond this?
vedasdoo avatar image
vedasdoo answered ·
Hi all,
Indeed, nothing has changed in terms of temperature compensation, despite the new FW ver. 1.63.
I have checked it thoroughly this time. As somebody stated before, put the numbers without "-" sign.
I believe it works well with "-" sign in case you have remote BVM device installed, but I do not need it in my application.
More important is how you set other critical parameters in your system.
Please, read this comment:
https://community.victronenergy.com/comments/240659/view.html
Regards
Marin
MPPT Product Page
MPPT Error codes
