ystwyth1 avatar image
Battery balancer 24v install
screenshot-20201222-171956.jpgHello I have looked around but cannot quite find the answer. I have a battery balancer to install on my bank its 8 12v 220ah agm in 24v config
My question is how to connect it up to the system. I have looked at the documents and am still some what lost
I assume it connects to plus on one side and negative on the other and then there is a mid point
From what I can see the mid point is a daisy chain along the plus on the 4 batterys
The plus and negative are as that connected to plus and negative no chain down the bank? If some one could help out I may still be sane by new year
AGM BatteryBattery Balancerbattery bms
ystwyth1 answered ·
The mid point is the part that I'm none to shore about, do i connect the mid in a daisy across all the mids or just to 1 point on the bank. So would be 4 connection points on the mid or just 1
I still don't get what your problem is. The schematic can't be easier.
All (+) 24V are connected together (to a busbar), all (-) 0V are connected together (to a busbar) and all mid-points are connected together (with some wires).
What exactly is your problem? Just wire it as shown in the manual.
