Kevin Windrem avatar image
Kevin Windrem asked
Venus alarm system - need the code
The current code only allows assigning Alarm, Generator start/stop, Pump) to the first relay. I'm planning to modify the code so that at least two additional relays can be assigned functions. I'm running on a Raspberry Pi that supports up to 6 relays.
The code that needs to change is in dbus-generator-starter and bus-pump for those two functions. But I can't find where the relay state is changed when it is set to Alarm.
Any one have any ideas?
Venus GX - VGXalarm
bathnm avatar image
bathnm answered ·
It is not hanged within the QML code, I suspect it is changed within the main GUI code and executable.
I suspect that there is a lot of code too change, to be able to enumerate the relays to a function. At present the relays function is tide to a single dBus path:
com.victronenergy.settings/Settings/Relay/Function
I have added code to the QML files to enumerate the relays to
com.victronenergy.settings/Settings/Relay/#/Function
But too change the Generator start/stop and Pump dbus services is a lot of work to maintain through code upgrades. Further there is not a service specific to Alarms so enumerating that away from anything than the Settings/Relay/Function path is not possible by us.
I have QML code that maintains the non enumerated value when relay 1 is set to Alarm, Generator start/stop or Pump, therefore my relay function screen is currently this for relay 1
and for the second relay the list is minus Alarm, Generator start/stop or Pump.
Happy to share some Diff files.
Kevin Windrem avatar image Kevin Windrem commented ·
Too bad they've hidden this stuff but it is what it is. I guess I'll take the same route as you, making relay 1 the only one that can access the alarm function.
Your code would be much appreciated. At least I can keep the enumeration of .../Function in the same place as you. Thanks.
Venus GX manual
Venus GX product page
