red-dirt avatar image
red-dirt asked
On Board 12V supply
Hello wanted to power a 12V DC cellular router from a 12V supply that remains active even when inverter is shutdown. Where would be the best point to get that supply from on a Victron system
offgrid
d-winterburn avatar image
d-winterburn answered ·
If you are looking for an always live 12Vdc feed then why not simply tap into your battery bank through an appropriately sized fuse for the cellular router? Your 12Vdc should be live all the time.
red-dirt answered ·
Thanks but this is a 48V battery
Justin Cook avatar image
Justin Cook answered ·
Hi @red-dirt,
If you have a 48v system that you need to pull 12v from, then you should use a 48-12 DC-DC Converter; which model you'll need depends on your 12v consumption requirements.
