dognose avatar image
dognose asked
Relais when restoring Grid?
I have a 3 phase victron system (MP 5000) that works as expected. When a grid failure is detected there is about a single "click" and the MPs are running offgrid. That seems fine, but what i'm not sure about:
When grid connectivity is restored, the MPs are starting a "Relais-celebration", toggling something with about 20Hz for at least 3-5 seconds.
Is that "normal" behaviour, something like a must-do functionality test of all relais, some sort of "soft-connect" to precharge some capacitors, or is this more an Issue that needs to be looked at?
Example
https://static.equinox-solutions.de/Victron/clicki-click.mp4
offgridgrid
nickdb avatar image
nickdb answered ·
The multiple clicks of the relays after grid recovery is normal.
iirc there are 4 relays on the input side,
dognose avatar image dognose commented ·
thx - I've just attached a example video, was a bit unsure about this :)
nickdb avatar image nickdb ♦♦ dognose commented ·
100% normal. Since you have 3 systems, it is even more noticeable.
Victron Offgrid page
