tristan avatar image
tristan asked
Cyrix-li-ct not charging house battery (with BMV 712)
Hi there, I hope someone can help.
I have a 100ah lifepo4 battery which is combined with the starter battery using a Cyrix-li-ct. The cyrix is earthed to the starter battery on the lower terminal and connected to a BMV 712 on the upper terminal. The BMV relay is configured to close when the state of charge gets low, and I can hear the relay clicking open and close when I fiddle with the settings/invert. The alternator is producing 14.4 volts with the engine running, but I'm seeing absolutely no current pass through the relay.
Is there something else I might be missing, or do I perhaps have a broken cyrix module?
BMV Battery MonitorCyrix Battery Combiner
