rondog avatar image
rondog asked
Converting RJ45 UDP cable to RJ12 UDP cable
I have an extra RJ45 UDP cable already installed behind a wall and would like to repurpose it for a the BMV-712 shunt to monitor RJ12 cable. Is it as simple as replacing the connectors with RJ12 6 pin connectors running six wires pin to pin?
wiring
Paul B avatar image
Paul B answered ·
Yes you can do that and it would work fine , make sure that the two ends are configured the same as what the RJ12 are
