stefanesai avatar image
stefanesai asked
Bmv702, two battery banks, with selector switch
I have two battery banks in my boat, one “house” bank which I need to keep control of, and one smaller bank for starting/backup.
The smaller bank is not a dedicated “starter battery”, I can choose bank 1 or 2 or both with the switch, and all equipment can be run of either (or both) banks.
I installed the bmv702 as per instructions, with the shunt between the house bank negative. The other bank was connected to load side of shunt.
I entered the capacity of the house bank (345Ah) and it works. But if I connect the banks together the A and W is wrong, as power is drawn from both banks, but only half through the shunt.
Now I am wondering if I should connect both banks to the same battery side of the shunt, and leave the 345 ah I stated as battery capacity. This way I will have an accurate reading of power consumption at all times whichever setting on the switch, and the only ”fault” will be that there actually is more ah available than what I have told the system (if using both banks). If using only house bank it will be right. Or will the system detect the extra ah’s, when voltage isn’t dropping according to the amps used?
I only need to know voltage on the second battery bank, but I really would like to have control over amps and watts used totally, and also I use both solar and battery charger connected to shore power for charging all batteries. Can I go wrong by connecting all negative batteries to battery side of shunt, and all other negative to the load side? Being aware that the ah capacity won’t always be correct, depending on which bank I use.
BMV Battery Monitor
Trina avatar image
Trina answered ·
You have made it unnecessarily complicated.
Wire the batteries as one bank and set the amp hours correctly. Don't have a 2nd house bank or ESSENTIALLY you have a separare system and it is unecessarily -unnecessarily- complex, which is ALWAYS bad in a boat.
Add a starter and use the aux lead on your shunt to get voltage.
You CAN wire all grounds together and ALL loads of course and drop the ground right in and ground the whole ocean just like a counterpoise on a SSB -the BMV only measures the completed circuit through whatever the positive lead finishes the loop -like your radio or something. There is no circuit in the ocean to measure so it won't do anything per say but you could start picking up on voltag leaks and need to recalibrate far more frequently than.on land -unnecessarily complicated!
Just think of things as loops with the BMV only measuring whatever positive load is on the other side of that shunt as it finds "ground" and common ground being whatever you connect BACK to your negative bus bars and battery (ALL loads).
It will never work correctly for SOC with a switch because the two separate banks will never exactly parallel each other except in a theoretical universe.
It gets even worse with lithium or anything mixed at all but exactly the same batteries all around and they should be wired as simple as possible for function.
Get a second monitor and decide on a simpler system that won't be so complex and potentially break easier. Or wire it all as one house.bank -you don't want to be using starter batteries for house loads and house batteries to start except in emergencies. unless everything is lifepo4 and then why have them separate at all?
Simplify
Or get an second completely correctly set up system and monitor. I can certainly understand the desire for ultimate flexibility via a switch but then why use an expensive BMV vs simple old-school volt and amp meters? You use the BMV because it offfers those special functions like a SOC! But your setup negates these features! So maybe you would be better served with simple volt meters...? A few days on the water and you would know how to read your charge states pretty quickly.
You could get a lot of heavy marine wires and gauges for the cost of that BMV!
If money is the issue and you really can NOT combine the banks and can't get a 2nd BMV there is a similar monitor mademin China, by Hangchen? It is NOT a rip off of victron gear and not as cool as the BMV and not as good for flooded batteries but it would work. It's harder to get calibrated and lacks the coolest victron functions but it would work for someone on a tight budget. You would need to keep the systems separated as usual. Complicated.
Alexandra avatar image
Alexandra answered ·
@Stefanesai
The BMV 702 offers comprehensive monitoring of a single battery bank and basic monitoring (i.e.) voltage of a second battery.
Since the shunt 'counts' power in and out of a battery it is not possible to have accurate monitoring or two banks even if you did manage to safely make a way to switch between the two.
As @Trina mentioned it is better to have two monitors or settle for the basic voltage monitoring option.
https://www.victronenergy.com/battery-monitors/smart-battery-shunt.
This is also an option if you don't need the face or extra wiring.
