Hi, I'm testing Venus OS on Raspberry with SolarEdge inverter. The inverter can be seen in the GX visualization, the modbus ID received 20. I'm trying to scan addresses, but I'm still getting errors. Gateway Path Unavailable
Looks like you have to set the SolarEdge Device ID 126 as mentioned there https://community.victronenergy.com/questions/12227/victron-venus-gx-solaredge-se10k-3-phase-inverter.html
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
24 People are following this question.
