timh avatar image
timh asked
KVA hours or kWh
Hi, I have an Victron installation with a CCGX which at present is connected to a shoreline all the time. When I check the production report at the end of the month there is a big difference between the shore meter ( which I know to be correct) and the production report downloaded from the VRM portal. (shore meter 183 kWh, VRM report 210 kWh) Could the VRM report actually be KVA h and not kWh ?
kwh
Paul B avatar image
Paul B answered ·
As far as I know its KWhs
How do you know the shore meter to be correct? And accounting for power factor and reporting kWh and not kVAh?
It is quite common for energy meters to not account for power factor here in Australia.
Given the shorepower number is lower, that would seem more likely?
The Multiplus current sensor is not accurate to metering grade, not even close. You can use an energy meter connected to a Venus-device for precise energy measurement if this is very important.
https://www.victronenergy.com/accessories/energy-meter
timh avatar image timh commented ·
Thanks for your reply Guy,
Im pretty certain tht the shore meter is correct as I have a consumer meter fitted on hte boat on the shoreline and they both agree. I guess the best thing to do is when I have some data I can work out an approximate correction factor,
Brgs Tim
timh avatar image
timh answered ·
Brgs Tim
