damjeff avatar image
damjeff asked
Old Multiplus low temperature cutoff
I have an old Multiplus 24/3000/70 (still has VE-Bus, it's the 19xxxx model), a BMV 712 and a 30a smartsolar MPPT. I've purchased a large "drop-in" LiFePO4 battery with no LT cutoff and no external comms. Can anyone assist with low temperature cut off?
- I know how to do this with the MPPT - (either by using a temperature sensor to BMV712 or using a Smart Sense and linking with Bluetooth.
- The question is, how do I cut off the Multiplus (someone accidentally turns generator on to charge for instance and it's below 5 degrees in battery compartment. Do I use the same sensor and use an assistant and 2 wires (not sure how this works) from the BMV 712? Should I use a smart sense bluetooth connection for MPPT and a separate wired temperature sensor?
Any help would be really appreciated.
Temperature Sensor
ecowhale avatar image
ecowhale answered ·
If the BMV-712, etc. don't auto cut off due to low temp and you want a manual cut off, then you will need a disconnect switch (a batter disconnect switch will work for an inverter too) or a high amp (200A?) fuse with reset push button.
damjeff avatar image damjeff commented ·
I don't understand, how does this fit into the auto temp disconnect I'm talking about?
Victron temperature sensor disambiguation table - which product supports which sensor
