cottersay avatar image
cottersay asked
BMV-712 Monitor with Temperature Sensor with TWO 12V batteries??
I have the Victron BMV-712 Battery Monitor with Battery Temperature Sensor hooked up to my single BB lithium 12V 100Ah battery, but now I am adding another BB Lithium 12V 100Ah in parallel. My question is this: can I leave the temp sensor connected to the first battery, and then just program the BMV-712 to 200Ah, or should I discard the temp sensor and attach the B1 and B2 wires to each separate battery?
Which way makes the most sense?
BMV Battery MonitorTemperature Sensor
wkirby avatar image
wkirby answered ·
If that battery is going to be wired in parallel and just be an extension of the first one then keep the temperature sensor and adjust the BMV to 200Ah.
