j9g avatar image
j9g asked
Can the Orion-Tr Smart Charger be in series with a Combiner Relay?
Does the Orion TR Smart Charger have voltage present on the input terminal with no source connected? I ask this because the set-up I have already includes a voltage sensing combiner relay closest to the Start battery. The combiner won't close-in to admit input power to the charger unless there is a voltage present.
orion-tr smartCyrix Battery Combiner
alex-rhys-hurn avatar image
alex-rhys-hurn answered ·
I tried this and it does not work.
I replaced my cyrix ct with a battery disconnect switch.
The cyrix needs to see voltage both sides before it will combine.
The orion needs voltage on the inout before it will startup.
Alex
