antoniomoura avatar image
antoniomoura asked
Small kits for villages in Nigeria?
Good Morning,
I would like your opinion for the kits that will be for Africa.
All material will have to be from Victron and will be installed in villages without electricity in Nigeria.
Our client asked us if it would be possible to make kits of different powers for basic consumption with autonomy only for a few hours at night (250w and 375w are just led lighting and charging cell phones, the 800W for led lighting and a refrigerator) where a small generator can be coupled (Kit 4, 5 and 6).
Kits without Generator connection
250W Kit 1
1 MODULE Victron 175w Monocrystalline
1 Blue Solar MPPT 75/15
1Phoenix 12/250 230V Ve. Direct Schuko
1 Victron Energy 12 V 60 Ah gel battery
375W Kit 2
2 MODULO Victron 175w Monocrystalline
1 SmartSolar MPPT 100/20
1Phoenix 12/375 230V Ve. Direct Schuko
1 Victron Energy 12 V 90 Ah gel battery
800W Kit 3
2 MODULE Victron 360w Monocrystalline
1 Blue solar MPPT 150/45 tr
1Phoenix 24/800 230V Ve. Direct Schuko
2 Victron Energy 12 V 90 Ah gel battery
Kits with possible connection of generators for battery charging
800W Kit 4
1 smartSolar MPPT 250/70 Tr Ve.can
1 Victron Multiplus 12/800 / 35-16
1200W Kit 5
3 MODULE Victron 360w Monocrystalline
1.6kW Kit 6
4 MODULO Victron 360w Monocrystalline
Victron Easysolar 24/1600 / 40-16 MPPT 100-50
offgrid
The first thing that will happen if you supply inverters, will be someone plugging in a power tool, or an immersion heater and destroying inverters and batteries.
Lighting and charging mobile devices can be done from 12v, and 12v to 5v usb converters.
michelg avatar image
michelg answered ·
Hi, avoid generators for recharging batteries, they are usually used as backups, but consider increasing the size of the solar panels and batteries. Also, much better keeping all the setup with low voltage 12/24V for lighting & mobile phone charging station via USB. Esay to find, costless, regarding the refrigerators, you can find STECA PF-166 working at 12/24V, eliminating the need of an inverter and that could be run with its own solar panel.
https://www.steca.com/index.php?Steca-PF-166-H-240-H-en
