bdahlmann avatar image
bdahlmann asked
2 Signal BMS Assistant for Unconventional use
Writing in hopes that someone in the community may have experience with the implications of employing the 2 Signal BMS Assistant on a Non-Lithium system.
Specifically, I am working to commission a pair of Quattros which have some unconventional demands. In particular, there are times when the devices should perform as Chargers only, and times when they should behave as Inverters only.
While I do not see a convenient way to orchestrate this through direct means, it can be seen that the 2 Signal BMS assistant would realize this exact demand.
Is there a way to arrive at the same commands without misappropriating this Lithium assistant?
Assistants
Hi @bdahlmann
There are a lot of creative things you can do with assistants, and what you're discribing probably works fine.
But as always you'll have to test it.
