campinginthevan avatar image
campinginthevan asked
Can a Multiplus 12/3000/120 charge a lithium 3S battery at 12.6V?
I can get a good deal on a Lithium-ION 3S battery, so not a lifepo4 battery.
This battery should be charged at 12.6V.
Rated voltage
11.1V
Max. Continuous Charge Voltage
12.6V
Can i use my current Multiplus 12/3000/120 to charge this battery?
Lithium Batterycharger
You are very flexible with the charging settings. I'm sure you can set it up to suit your battery.
To check the possible options open VE.config -> Port selection -> Fake target with full options
Chargers.
Battery Compatibility
