We have a Victron MultiPlus 12/3000 rated at 2,400W or 3,000VA.
Which of these limits takes priority? For instance, if I'm running purely resistive loads with a power factor of 1.0 at a voltage of 120V, can I use 20A or 25A?
Hi @Matt Knight
At a power factor of 1, which is a resistive load, the unit is rated for 2400W at 25 degrees C. Battery voltage stability will also be a factor (higher voltage needs less current, and good connections mean less ripple).
The 3000VA rating is for a non-linear load with a crest factor 3:1. There is more explanation about what this means (and how you can have both 2400W and 3000VA ratings) in the AC chapter of Wiring Unlimited.
21 People are following this question.
