Since the weekend 15-11-20 the Google maps interface on the advanced tab is broken.
Am I the only one seeing this:
@LaurenceH No you are not alone. I suspect that the API key has not been renewed / API no longer valid in the integration of the VRM Portal.
@mvader (Victron Energy) I think somebody from the VRM Portal development needs to take a look at the API key for the Google Map integration.
Hi both,
Thanks for reporting, I'll made sure the VRM team sees it.
23 People are following this question.
