I have Color Control GX connected to Multi by a long CAT6 cable (about 130 m). Cable is in the ground at about 40 cm depth in network conduit. It used to work fine.
Yesterday we had a huge thunderstorm - fantastic fireworks show. And Color Control stopped working. Now it shows only a white screen. There is still some life inside as screen goes off after some time. However, there is no response on any buttons, no internet connection. Just white screen.
I guess lighting might strike somewhere close by and induced high power in the cable that killed something in the device. This hypothesis does not sound realistic but I got a PoE switch connected to an ethernet cable laying next to the above-mentioned cable died at the same time.
Question: is it possible to do anything to restore Color Control GX? Thank you.
