I have added the cerbo gx and have waited for the custom setting to be added for the ohms setting for tank senders but my senders are outside the custom limits, mine are 10-300 ohms.
Can the limits be increased??
Same here - Sensor value is 371.3 (about 90% full water tank) and max value is 300 Ohms.
Seems to be no solution since 2020? sad to see....
@Revolution
What you can do is to add a resistor paralell to the tank sensor.
In the case of @rob-roy he has 371.3 ohm by 90%.
That makes 412,5 ohm at 100% from his tank sensor at max.
To get a max of the Cerbo GX needed 300 ohm you can add a 1100 ohm (1.1K) resistor paralell to your cable connection inside thehousing of the tank sensor or at the tank input of the Cerbo GX.
Try it: it has workedon may VAN's
Please look here - Resistor calculator: https://www.omnicalculator.com/physics/parallel-resistor
22 People are following this question.
